Charmed Spark K8s
- Canonical | bundle
6. Using Apache Kyuubi
Apache Kyuubi is a gateway to serverless SQL running on Kubernetes, bridging the gap between Apache Spark as a data processing framework and a data lakehouse platform.
This hands-on tutorial stage aims to help you learn how to use Charmed Apache Kyuubi K8s and become familiar with its available operations.
Environment variables
At this step of the tutorial, you’ll need some environment variables that were set earlier during the environment setup stage. If you’ve restarted the VM and lost those variables, refresh them by running the following commands:
export ACCESS_KEY=$(kubectl get secret -n minio-operator microk8s-user-1 -o jsonpath='{.data.CONSOLE_ACCESS_KEY}' | base64 -d)
export SECRET_KEY=$(kubectl get secret -n minio-operator microk8s-user-1 -o jsonpath='{.data.CONSOLE_SECRET_KEY}' | base64 -d)
export S3_ENDPOINT=$(kubectl get service minio -n minio-operator -o jsonpath='{.spec.clusterIP}')
Initial setup
Let’s create a fresh Juju model for the Charmed Apache Kyuubi K8s experiments:
juju add-model lakehouse
To create our simple, minimal data lakehouse, we need an object storage.
Object storage
We will use the MinIO, installed in the environment setup stage of this tutorial. Let’s set up a new bucket:
aws s3 mb s3://lakehouse
Now add the spark-events directory to the bucket:
aws s3api put-object --bucket spark-tutorial --key spark-events/
You can check the result of directory creation by calling the list of elements in the bucket:
aws s3 ls spark-tutorial
The resulted output should contain the spark-events directory we have just created.
To provide access to our object storage, we can use the S3-integrator charm. Let’s deploy the charm first:
juju deploy s3-integrator --channel 1/stable
Now configure the s3-integrator application to have access to our object storage:
juju config s3-integrator bucket=spark-tutorial path="spark-events" endpoint=http://$S3_ENDPOINT
juju run s3-integrator/0 sync-s3-credentials access-key=$ACCESS_KEY secret-key=$SECRET_KEY
We will deploy the Spark Integration Hub K8s charm to manage integrations and configure service accounts on Kubernetes.
To deploy it and integrate with the object storage integrator charm:
juju deploy spark-integration-hub-k8s --channel 3/stable --trust integration-hub
juju integrate integration-hub s3-integrator
Authentication database
We need a database to hold our users. Let’s use the Charmed PostgreSQL K8s charm for that:
juju deploy postgresql-k8s --channel 14/stable --trust auth-db
External access
To enable external clients to connect to our lakehouse, we need the Data Integrator charm:
juju deploy data-integrator --channel latest/stable --config database-name=test
Deploy Charmed Apache Kyuubi K8s
We are now ready to deploy the Charmed Apache Kyuubi K8s charm, and integrate it with the previously prepared charms:
juju deploy kyuubi-k8s --channel 3.4/stable --trust --config expose-external=loadbalancer
juju integrate kyuubi-k8s integration-hub
juju integrate kyuubi-k8s:auth-db auth-db
juju integrate kyuubi-k8s data-integrator
Check the list of charms that have been deployed and their statuses:
watch -c juju status --relations --color
Wait until the status to be active for each charm:
lakehouse microk8s microk8s/localhost 3.6.8 unsupported 16:43:19+02:00
auth-db 14.15 active 1 postgresql-k8s 14/stable 495 10.152.183.19 no
data-integrator active 1 data-integrator latest/stable 181 10.152.183.94 no
integration-hub active 1 spark-integration-hub-k8s 3/stable 67 10.152.183.220 no
kyuubi-k8s 1.10 active 1 kyuubi-k8s 3.4/stable 109 10.152.183.84 no
s3-integrator active 1 s3-integrator 1/stable 146 10.152.183.103 no
auth-db/0* active idle 10.1.111.95 Primary
data-integrator/0* active idle 10.1.111.66
integration-hub/0* active idle 10.1.111.101
kyuubi-k8s/0 active idle 10.1.111.80
s3-integrator/0* active idle 10.1.111.77
Access Charmed Apache Kyuubi K8s
Apache Kyuubi provides an SQL gateway through Thrift JDBC/ODBC interface for end-users. Get the JDBC endpoint and its credentials with the following command:
juju run data-integrator/0 get-credentials
The resulted output should look like the following:
kyuubi:
data: '{"database": "test", "external-node-connectivity": "true", "provided-secrets":
"[\"mtls-cert\"]", "requested-secrets": "[\"username\", \"password\", \"tls\",
\"tls-ca\", \"uris\", \"read-only-uris\"]"}'
database: test
endpoints: 10.64.140.43:10009
password: 31rwWzk8wpnhoZvU
tls: "False"
uris: jdbc:hive2://10.64.140.43:10009/
username: relation_id_15
version: 1.10.2
ok: "True"
Check your output and locate the endpoint, username, and password values, that we will use to connect using Beeline and DBeaver clients below.
By default, there is no data in a freshly installed system. If you want to generate and upload a sample dataset, feel free to use this Kyuubi Dataset generator.
Beeline
Beeline is a CLI JDBC client, that is available to you via spark-client.
Use the spark-client.beeline command with the credentials from previous command to access
the endpoint with the beeline JDBC-compliant client:
spark-client.beeline -u "jdbc:hive2://<endpoints>/" -n <username> -p <password>
For example, using the data from the previous output example, the command should look like that:
spark-client.beeline -u "jdbc:hive2://10.64.140.43:10009/" -n relation_id_15 -p 31rwWzk8wpnhoZvU
The client should welcome you with a prompt where you can run SQL queries.
(Optional) DBeaver
DBeaver Community is a free cross-platform database GUI tool. Since it’s using graphical user interface, we won’t run it in a Multipass VM.
Install DBeaver on the host machine (outside of the Multipass VM) by using the Downloads page or the following command:
sudo snap install dbeaver-ce
Run DBeaver after installation and open Connect to a database window by clicking
the New Database Connection button or pressing the Ctrl + Shift + N key combination.
Select Apache Kyuubi and press Next.
Fill in the following fields:
- Connect by – select URL
- JDBC URL – use the
urisvalue from before. Alternatively, you can prepend theendpointsvalue with thejdbc:hive2://and use it instead. - Username – use the
usernamevalue - Password – use the
password
Now press Finish and then, the Connect button in the horizontal ribbon menu. After a successfull connection, you can create and run your SQL queries in the right side of the interface.
High availability
Apache Kyuubi has two major HA features:
- Horizontal scaling
- External metastore
Let’s try using both of them.
Horizontal scaling
Scale out the Apache Kyuubi cluster up to three nodes:
juju scale-application kyuubi-k8s 3
Wait for the deployment to complete and check the model status with the juju status command.
The kyuubi-k8s units are all in the blocked state now, with a message “Missing ZooKeeper integration”.
That is because multi-node Apache Kyuubi deployments require Apache ZooKeeper for synchronisation.
Now, deploy Apache ZooKeeper K8s charm (three nodes, since we want high availability) and integrate it with Apache Kyuubi:
juju deploy zookeeper-k8s --channel=3/stable --trust -n 3
juju integrate kyuubi-k8s zookeeper-k8s
Wait for the deployment to finish by watching the juju status until all workloads are active and all agents are idle.
External metastore
By default, Apache Kyuubi units in Juju store metadata on the local pod storage. This means that if a pod is reset or fails, the metadata is lost.
To make metadata persistent, configure an external metastore by deploying Charmed PostgreSQL and integrating it with the Apache Kyuubi charm using the metastore-db interface:
juju deploy postgresql-k8s --trust --channel=14/stable metastore
juju integrate kyuubi-k8s:metastore-db metastore
Enable TLS encryption
TLS is enabled by integrating with the Self-signed certificates charm. This charm centralises TLS certificate management consistently and handles operations like providing, requesting, and renewing TLS certificates.
For this tutorial, we are using the self-signed-certificates charm.
Avoid using self-signed TLS certificates for production environments.
Please refer to the X.509 certificates post for an overview of the TLS certificates provider charms and some guidance on how to choose the right one for your use case.
Before enabling TLS on Charmed Apache Kyuubi K8s, deploy the self-signed-certificates charm to use as a certificate provider:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
Wait for the charm to settle into an active/idle state, as shown by the juju status.
To enable TLS on Charmed Apache Kyuubi K8s, integrate the kyuubi-k8s charm with the self-signed-certificates charm:
juju integrate kyuubi-k8s self-signed-certificates
After the charms settle into active/idle states, the Charmed Apache Kyuubi K8s endpoint should now accept encrypted traffic.
Requesting the credentials again should now display the certificate:
kyuubi:
database: test
tls: "True"
tls-ca: |-
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
version: 1.10.2
ok: "True"
Test the server certificate by requesting it using openssl on the endpoint returned above:
sudo snap install yq
openssl s_client -showcerts -connect $(juju run data-integrator/0 get-credentials | yq ".kyuubi.endpoints") < /dev/null
The resulted output should include issuer CN Tutorial CA.
To connect to Charmed Apache Kyuubi K8s using the spark-client’s bundled beeline client, import the certificate in the spark-client snap:
juju run data-integrator/0 get-credentials | yq ".kyuubi.tls-ca" > cert.pem
spark-client.import-certificate tutorial-cert cert.pem
Then, add ;ssl=true to the JDBC endpoint you got from the data-integrator charm, for example:
spark-client.beeline -u "jdbc:hive2://10.64.140.43:10009/;ssl=true" -n relation_id_15 -p 31rwWzk8wpnhoZvU
The client should welcome you once again with a prompt where you can run SQL queries.
Congratulations! You are now connected to Charmed Apache Kyuubi K8s using TLS.
