Charmed Spark K8s
- Canonical | bundle
2. Distributed data processing
In this section, you will learn how to use PySpark and Spark Submit to run your Spark jobs. Make sure to finish setting up the environment from the Environment setup page.
PySpark shell
The spark-client snap comes with a built-in Python shell where we can execute commands interactively against an Apache Spark cluster using the Python programming language.
To proceed, run the PySpark interactive CLI, specifying the service account to be used for retrieving configurations and running the executor pods (see more information below)
spark-client.pyspark --username spark --namespace spark
Once the shell is open and ready, you should see a welcome screen similar to the following:
Welcome to
____ __
/ __/__ ___ _____/ /__
_\ \/ _ \/ _ `/ __/ '_/
/__ / .__/\_,_/_/ /_/\_\ version 3.4.2
/_/
Using Python version 3.10.12 (main, Jan 17 2025 14:35:34)
Spark context Web UI available at http://10.181.60.89:4040
Spark context available as 'sc' (master = k8s://https://10.181.60.89:16443, app id = spark-79ab7a21242c4a81bc88c1f71348c102).
SparkSession available as 'spark'.
When you open the PySpark shell, Charmed Apache Spark spawns a couple of executor K8s pods in the background to process commands.
You can see them by fetching the list of pods in the spark namespace in a separate VM shell:
kubectl get pods -n spark
You should see output lines similar to the following:
NAME READY STATUS RESTARTS AGE
pysparkshell-xxxxxxxxxxxxxxxx-exec-1 1/1 Running 0 5s
pysparkshell-xxxxxxxxxxxxxxxx-exec-2 1/1 Running 0 5s
As you can see, PySpark spawned two executor pods within the spark namespace. This is the namespace that we provided as a value to the --namespace argument when launching spark-client.pyspark. It’s in these executor pods that data is cached and the computation will be executed, therefore creating a computational architecture that can horizontally scale to large datasets (“big data”).
On the other hand, the PySpark shell started by the spark-client snap will act as a driver, controlling and orchestrating the operations of the executors. More information about the Apache Spark architecture can be found in the Apache Spark documentation.
The PySpark shell is just like a regular Python shell with Apache Spark Context that can be easily accessed with variables sc and spark respectively. You can even see this printed in its welcome screen.
String processing
Let’s try a simple example of counting the number of vowel characters in a string.
Using PySpark shell, run the following to set the string variable lines that we are going to use:
lines = """Canonical's Charmed Data Platform solution for Apache Spark runs Spark jobs on your Kubernetes cluster.
You can get started right away with MicroK8s - the mightiest tiny Kubernetes distro around!
The spark-client snap simplifies the setup process to get you running Spark jobs against your Kubernetes cluster.
Apache Spark on Kubernetes is a complex environment with many moving parts.
Sometimes, small mistakes can take a lot of time to debug and figure out.
Now use the following code to add a function that returns the number of vowel characters in a string:
def count_vowels(text: str) -> int:
count = 0
for char in text:
if char.lower() in "aeiou":
count += 1
return count
To test this function, the string lines can now be passed into it so the number of vowels will be returned to the console as follows:
count_vowels(lines)
As a result, you should see the value returned by the function: 137.
However, this approach does not leverage parallelization or the distributed processing capabilities of Apache Spark. It simply executes the Python code.
Since Apache Spark is designed for distributed processing, we can run this task in parallel across multiple executor pods. This parallelization can be achieved as simply as:
from operator import add
spark.sparkContext.parallelize(lines.splitlines(), 2).map(count_vowels).reduce(add)
If you get an error message containing java.io.InvalidClassException, like this:
java.io.InvalidClassException: org.apache.spark.scheduler.Task; local class incompatible: stream classdesc serialVersionUID = -3760150995365899213, local class serialVersionUID = -8788749905090789633
Make sure your Apache Spark image used on the drivers and executors has the same version of Apache Spark as your local spark.client. You can do that by manually setting the version of image used on the cluster side:
spark-client.service-account-registry add-config --username spark --namespace spark --conf spark.kubernetes.container.image=ghcr.io/canonical/charmed-spark:3.4.2-22.04_edge
Here, we split the data into two parts, generating a distributed data structure, where each line is stored in one of the (possibly many) executors.
The number of vowels in each line is computed, line by line, with the count_vowels function on each executor in parallel.
Then the numbers are aggregated and added up to calculate the total number of occurrences of vowel characters in the entire dataset.
This kind of parallelization of tasks is particularly useful in processing very large data sets which helps to reduce the processing time significantly, and it is generally referred to as the MapReduce pattern.
The returned result should be the same as we’ve seen earlier, with a non-distributed version: 137.
To continue with this tutorial, leave the PySpark shell: run exit() or press Ctrl + D key combination.
Dataset processing
Apache Spark is made to efficiently analyze large datasets across multiple nodes. Often times, the data files to be processed contain a huge amount of data, and it’s common to store them in an S3 storage and then have jobs read data from there in order to process it.
Let’s download a sample dataset, store it in an S3 object storage, and do some distributed processing with PySpark.
Prepare a dataset
For the purpose of this tutorial, we will use a dataset from Kaggle with over 3 million tweets: Customer Support on Twitter.
If you download and check this dataset, you’ll see it contains seven columns/fields, but we are only interested in the one with the header text.
The dataset takes more then 500 MB of disk space, and we will process it on multiple Apache Spark executors.
First, let’s download the dataset to the VM:
curl -L -o ./twitter.zip https://www.kaggle.com/api/v1/datasets/download/thoughtvector/customer-support-on-twitter
Now let’s install zip and extract the archive:
sudo apt install zip
unzip twitter.zip
This archive unpacks a directory called twcs with a single csv file of the same in it.
Let’s upload it to our S3 storage:
aws s3 cp ./twcs/twcs.csv s3://spark-tutorial/twitter.csv --checksum-algorithm SHA256
Now the dataset is stored in our MinIO instance: in the spark-tutorial bucket with the filename twitter.csv.
You can check this by listing all files in the bucket:
aws s3 ls spark-tutorial
Distributed dataset processing
To demonstrate how simple it is to use distributed data processing in Charmed Apache Spark, let’s count the number of tweets that mention Ubuntu. Start the PySpark:
For distributed and parallel data processing Apache Spark actively uses the concept of a resilient distributed dataset (RDD), which is a fault-tolerant collection of elements that can be operated on in parallel across the nodes of the cluster.
Read CSV from S3 and create an RDD from our sample dataset:
rdd = spark.read.csv("s3a://spark-tutorial/twitter.csv", header=True).rdd
Now that RDD can be used for parallel processing by multiple Apache Spark executors.
Count the number of tweets (lines in CSV) with “text” field containing “Ubuntu” in a case insensitive way:
count = rdd.map(lambda row: row['text']).map(lambda cell: 1 if isinstance(cell, str) and "ubuntu" in cell.lower() else 0).reduce(add)
Here, we extract the value of the text column for each row and for each value we convert it to lower case and check whether it contains ubuntu. If it does, we return 1, otherwise - 0.
Finally, on a reduce step, we add up all values (ones and zeroes), resulting in the total number of rows that mention ubuntu.
To get the answer, we just need to print it:
print("Number of tweets containing Ubuntu:", count)
The result should look similar to the following:
Number of tweets containing Ubuntu: 54
Run a script
Charmed Apache Spark comes with a command that can be used to submit Spark jobs to the cluster from scripts written in high-level languages like Python and Scala. For that purpose, we can use the spark-submit command from the spark-client snap.
Prepare a script
For a quick example, let’s see how it can be done using slightly refactored code from the previous section:
from pyspark.sql import SparkSession
def contains_ubuntu(text):
return 1 if isinstance(text, str) and "ubuntu" in text.lower() else 0
# Create a Spark session
spark = SparkSession\
.builder\
.appName("CountUbuntuTweets")\
.getOrCreate()
# Read the CSV file into a DataFrame and convert to RDD
# Count how many rows contain the word "ubuntu" in the "text" column
count = (
rdd.map(lambda row: row["text"]) # Extract the "text" column
.map(contains_ubuntu) # Apply the contains_ubuntu function
.reduce(add) # Sum all the 1 and 0 to get the total number of matches
# Print the result
print(f"Number of tweets containing Ubuntu: {count}")
spark.stop()
We’ve added a few more lines to what we’ve executed so far. The Apache Spark session, which would be available by default in a PySpark shell, needs to be explicitly created. Also, we’ve added spark.stop() at the end of the file to stop the Apache Spark session after completion of the job.
Let’s save the aforementioned script in a file named count-ubuntu.py and proceed further to run it.
Run
When submitting a Spark job, the driver won’t be running in the local machine but on a K8s pod, hence the script needs to be downloaded and then executed remotely on Kubernetes in a dedicated pod. For that reason, we’ll copy the file to the S3 storage to be easily accessible from K8s pods.
Upload the file to the Multipass VM:
multipass transfer count-ubuntu.py spark-tutorial:count-ubuntu.py
where spark-tutorial is the name of the VM.
Copy the file to the S3-compatible storage:
aws s3 cp count-ubuntu.py s3://spark-tutorial/count-ubuntu.py
Now run the script by issuing the following command:
spark-client.spark-submit \
--username spark --namespace spark \
--deploy-mode cluster \
s3a://spark-tutorial/count-ubuntu.py
The --deploy-mode cluster option tells Spark Submit to run the driver on a K8s pod.
When you execute the command, the console will display log output showing the state of the pods running the task.
While the spark-submit command spins up K8s pods and runs the script, you can check the K8s pods statuses by running the following command in a different shell on the VM:
watch -n1 "kubectl get pods -n spark"
You should see output similar to the following:
count-ubuntu-py-752c77960d097604-driver 1/1 Running 0 11s
countubuntutweets-a4b68a960d0982c4-exec-1 1/1 Running 0 8s
countubuntutweets-a4b68a960d0982c4-exec-2 0/1 Pending 0 8s
Here, we have a “driver” pod, that will be executing the script and spawning and coordinating the other two “executor” pods.
The state of the pods transitions from Pending to Running and then, finally, to Completed.
Once the job is completed, the driver and the executor pods are transitioned to the Completed state. The executor pods are deleted automatically.
The script prints the result to the console output, but that’s the driver’s console. To see the printed message, let’s find the driver pod’s name and filter the logs from it:
pod_name=$(kubectl get pods -n spark | grep "count-ubuntu-.*-driver" | tail -n 1 | cut -d' ' -f1)
kubectl logs $pod_name -n spark | grep "Number of tweets containing Ubuntu:"
2025-04-07T11:32:44.872Z [sparkd] Number of tweets containing Ubuntu: 54
By default, Apache Spark stores the logs of drivers and executors as pod logs in the local file systems, which are lost once the pods are deleted. Apache Spark can store these logs in a persistent object storage system, like S3, so that they can later be retrieved and visualised by a component called Spark History Server.
