Charmed Spark K8s
- Canonical | bundle
Charmed Apache Spark (revision 2)
Jul 29, 2025
We’re excited to introduce Apache Kyuubi as part of our expanded Apache Spark charmed bundle—bringing enhanced multi-tenant support and a simplified SQL interface for big data analytics.
This release includes Apache Kyuubi, the Spark History Server, Spark Integration Hub, Spark Client Snap, and Apache Spark OCI Images to deliver a seamless, production-ready fully open-source data lakehouse experience. The Charmed Apache Spark with Apache Kyuubi is available on charmhub.io at the 3.4/stable and 3.5/stable channels.
Charmhub: 3.4/stable, 3.5/stable | Docs | Deploy guide | System requirements
Features
General
- [DPE-4344;DPE-2863] Bundle implementation and integrated testing
- [DPE-5784] Azure AKS solution validation
Kyuubi
- [DPE-2858] Basic charm functionalities and testing (s3 support)
- [DPE-4324] Support for Azure Object Storage and ADLSv2
- [DPE-4349] Enable Kyuubi server high-availability
- [DPE-4351] Canonical Observability Stack integration
- [DPE-5783] Support for external access with Kubernetes NodePort and LoadBalancer
- [DPE-5805] Enable JDBC endpoint encryption
- [DPE-7087;DPE-4350] In-place upgrades with v3 user-experience
- [DPE-7089] Canonical built artifact to provide bug fixes and security patching
- [DPE-7090] Backup and Restore
- [DPE-2471] Upgrade to Juju 3
- [DPE-2859] OIDC authentication
- [DPE-3491] Add tls-chain support in the Spark History Server
- [DPE-6266] Prepare charm for charmcraft 3
- [DPE-2861] Basic charm functionalities and testing (s3 support)
- [DPE-3724] Create Integration Hub OCI image
- [DPE-5794] Implementation of client <> server charm relation
Spark Client Snap
- [DPE-2164] Expose Spark SQL in Spark Client snap
- [DPE-3552] Add self signed certificate handling to the Spark-Client on spark-submit
- [DPE-4482] Add tests for Azure Object Storage and ADLSv2
- [DPE-7131] Add beeline client to snap
Charmed Spark OCI Images
- [DPE-2164] Add Spark SQL into Charmed Spark Rock image
- [DPE-2858] Add Apache Kyuubi Image
- [DPE-3012] Add Volcano-integration binaries
- [DPE-3104] Create Jupyter notebook image
- [DPE-3194] Integrate Apache Iceberg jars with Rock Image
- [DPE-3514] Add Apache Kyuubi entrypoint to Charmed Spark base rock image
- [DPE-4324] Support for Azure Blob Storage and ADLSv2
- [DPE-4327] Create Spark Image with RAPIDS library for GPU support
Bug fixes
- [DPE-5036;DPE-3666] Create S3 bucket if not existing
- [DPE-6861] Invalid proxy base when exposed under a subdomain
Spark Client Snap
- [DPE-3472] Fix error when using S3 with Pyspark or Spark shell
- [DPE-3621] Fix usage of KUBECONFIG env variable
- [DPE-3017] Patch Pebble issue on shutdown on failure
Breaking changes
- [DPE-3067] Changes following up entrypoint service refactoring
(This change removed the python files needed by jupyter service, as the jupyter binaries were moved into a separate image to reduce the security surface of the image)
Other improvements
- [DPE-4325] Security hardening documentation
- [DPE-4326] SSDLC compliance and artifacts
- [DPE-508;DPE-1748;DPE-7089] Artifacts & distributions built from source
- [DPE-5849] Kyuubi usage documentation
Security
The new artifacts have been fixing the following CVEs:
| Severity | Fixed CVEs |
| Critical | CVE-2019-10202,CVE-2022-46337,CVE-2023-44981,CVE-2024-47561 |
| High | CVE-2019-0205,CVE-2019-10172,CVE-2020-13949,CVE-2021-22569,CVE-2021-22570, CVE-2021-31684,CVE-2022-3509,CVE-2022-3510,CVE-2022-46751,CVE-2023-1370, CVE-2023-39410,CVE-2023-43642,CVE-2023-52428,CVE-2024-23945,CVE-2024-25638, CVE-2024-36114,CVE-2024-47554,CVE-2024-7254,GHSA-xpw8-rcwv-8f8pe |
| Medium | CVE-2022-3171,CVE-2023-26048,CVE-2023-34462,CVE-2023-3635,CVE-2023-40167, CVE-2023-42503,CVE-2024-23944,CVE-2024-25710,CVE-2024-26308,CVE-2024-29025, CVE-2024-29131,CVE-2024-29133,CVE-2024-47535,CVE-2024-8184,CVE-2024-9823, CVE-2025-25193 |
| Low | CVE-2023-26049,CVE-2023-36479,GHSA-58qw-p7qm-5rvh |
Compatibility
| Component | Hardware architecture | Channel | Artefact | Charm revision | Minimum Juju version | Recommended Juju version |
| Apache Spark History Server | AMD64 | 3/stable | Charmed Apache Spark Image (Spark version: 3.5.5-ubuntu1) | 47 | v.3.4.3+ | v.3.6.8 |
| Spark Integration Hub | AMD64 | 3/stable | Integration Hub Image (3) | 67 | v.3.4.3+ | v.3.6.8 |
| Apache Kyuubi | AMD64 | 3.4/stable | Charmed Apache Kyuubi Image (Spark version: 3.4.4-ubuntu2, Kyuubi version: 1.10.2-ubuntu1) | 113 | v.3.4.3+ | v.3.6.8 |
| Apache Kyuubi | AMD64 | 3.5/stable | Charmed Apache Kyuubi Image (Spark version: 3.5.5-ubuntu1, Kyuubi version: 1.10.2-ubuntu1) | 112 | v.3.4.3+ | v.3.6.8 |
| Spark Client Snap | AMD64 | 3.4/stable | Spark version: 3.4.4-ubuntu2 | 84 | N/A | N/A |
| Spark Client Snap | AMD64 | 3.5/stable | Spark version: 3.5.5-ubuntu1 | 86 | N/A | N/A |
