title: Charmhub | Deploy Ranger K8s Operator using Charmhub - The Open Operator Collection
description: Deploy the latest version of Ranger K8s Operator as a Kubernetes Operator
  on any cloud.
url: https://charmhub.io/ranger-k8s/docs/how-to-group-management
# Ranger K8s Operator
[Business Data](https://charmhub.io/publisher/businessdata "View all packages from Business Data")
* [Business Data](https://charmhub.io/publisher/businessdata "View all packages from Business Data")
stable 33
juju deploy ranger-k8s
#### Contacts
##### Maintainers
+ [Commercial Systems](mailto:jaas-crew@lists.canonical.com)
* [Submit a bug](https://github.com/canonical/ranger-k8s-operator/issues)
# Group management in Apache Ranger
The Charmed Ranger Operator makes use of the [Ranger API](https://ranger.apache.org/apidocs/index.html) and [apache-ranger PyPi package](https://pypi.org/project/apache-ranger/) to manage users and groups. The source of users and group memberships is a `user-group-configuration.yaml` file provided to the charm as a configuration value `user-group-configuration`.
An example of this file is here:
ranger-k8s:
   user-group-configuration: |
      relation_2:
         users:
            - name: user1
              firstname: One
              lastname: User
              email: user1@canonical.com
            - name: user2
              firstname: Two
              lastname: User
              email: user2@canonical.com
         groups:
            - name: developers
              description: users with developer level access.
            - name: users
              description: users with select only access.
         memberships:
            - groupname: users
              users: [user1, user2]
            - groupname: developers
              users: [user2]
The charm contains a RangerGroupManagement class which will on configuration change to this parameter:
* Create new groups
* Delete groups no longer required
* Create new users (please note external users cannot be deleted via the API)
* Associate users with groups
* Remove user associations with groups that are no longer required
## Group management in related application
The Ranger plugin schedules regular download of Ranger policies (every 3 minutes) storing these policies within the related application in a cache. On access request, the requesting user’s UNIX group is used when comparing to Ranger group policies to determine access.
### Get relation ID
To automatically share this user and group information with the related charm, you must ensure the `relation_id` present in the `user-group-configuration.yaml` matches the corresponding application. The user data will then be available to the related application via the relation databag.
This can be done with:
juju show-unit <application name>/0 --format json | jq
### Trino relation
The configuration of these groups is done automatically on relation with the Ranger charm in the [Trino K8s charm](https://charmhub.io/trino-k8s).
