opensearch
OpenSearch
2/stable 168 24 Sep 2024
2/candidate 168 24 Sep 2024
2/beta 168 24 Sep 2024
2/edge 307 Yesterday
Ubuntu 24.04 Ubuntu 22.04
2/edge 306 Yesterday
How to enable JWT Authentication
This document shows how to enable authentication with JSON Web Tokens (JWT) in OpenSearch.
Prerequisites:
  • A running deployment of Opensearch on VM with minimum charm revision 275 (22.04) or 276 (24.04)
  • A valid JSON Web Token for testing, issued by the JWT provider of your choice
  • The signing-key with which the JWT was signed
The generation of JWT’s is not part of the scope of this document.
Deploy and configure JWT integrator
The configuration for JWT authentication is provided to OpenSearch via the JWT integrator charm.
Deploy the charm:
juju deploy jwt-integrator --channel 1/edge
After the deployment has settled, the charm will be in blocked status because of missing configuration. You can check this with juju status:
opensearch  dev-controller  localhost/localhost  3.6.8    unsupported  12:02:14Z
App                       Version  Status   Scale  Charm                     Channel   Rev  Exposed  Message
jwt-integrator                     blocked      1  jwt-integrator            1/edge      1  no       Missing 'signing-key' or 'roles-key' con... Run `status-detail`: 0 action required; 1 additional statuses.
opensearch                         active       3  opensearch                2/edge    276  no
self-signed-certificates           active       1  self-signed-certificates  1/stable  317  no
Unit                         Workload  Agent  Machine  Public address  Ports     Message
jwt-integrator/0*            blocked   idle   3        10.65.50.163              Missing 'signing-key' or 'roles-key' con... Run `status-detail`: 0 action required; 1 additional statuses.
opensearch/0*                active    idle   0        10.65.50.55     9200/tcp
opensearch/1                 active    idle   1        10.65.50.63     9200/tcp
opensearch/2                 active    idle   2        10.65.50.37     9200/tcp
self-signed-certificates/0*  active    idle   4        10.65.50.79
Now, configure the JWT parameters to JWT integrator. First, create a secret containing the signing-key:
juju add-secret jwt-key signing-key="<your-signing-key>"
Take a note of the secret URI for later.
Now grant permissions for the secret to JWT integrator:
juju grant-secret jwt-key jwt-integrator
Next step is to provide the secret URI as configuration option:
juju config jwt-integrator signing-key=<your-secret-URI>
Configure all other configuration options, according to your JWT provider:
juju config jwt-integrator roles-key=role subject-key=user jwt-url-parameter=jwt ...
Enable JWT in OpenSearch
Now it’s time to enable JWT authentication in OpenSearch. This is done by integrating the JWT integrator with OpenSearch:
juju integrate jwt-integrator opensearch
After a few moments, OpenSearch has applied the provided configuration and updated its security plugin. Now you can query Opensearch with your JWT:
curl --header "Authorization: Bearer <your-jwt-here>" -XGET "https://<ip-address>:9200/_cat/nodes" -k
Large Deployments
If you have an OpenSearch large deployments cluster, it is required to integrate the JWT integrator with the main-orchestrator of your large deployment.
Check which of your deployed OpenSearch applications is the main-orchestrator by checking the integrations section of juju status:
Integration provider                           Requirer                                Interface           Type     Message
opensearch-main:peer-cluster-orchestrator      opensearch-data:peer-cluster            peer_cluster        regular
Now integrate the JWT integrator with this application:
juju integrate jwt-integrator opensearch-main
If the wrong application of your large deployments is integrated with the JWT integrator, you will see a blocked status:
jwt-integrator                     active       1  jwt-integrator            1/edge           1  no
opensearch-data                    blocked      3  opensearch                                 3  no       JWT relation must be created with Main-cluster-orchestrator
opensearch-failover                active       1  opensearch                                 1  no
opensearch-main                    active       1  opensearch                                 2  no
self-signed-certificates           active       1  self-signed-certificates  latest/stable  264  no
Enabling JWT authentication with OpenSearch Dashboards
To use JWT authentication in the OpenSearch Dashboards UI, all you need to do is integrate the JWT integrator with Opensearch Dashboards:
juju integrate jwt-integrator opensearch-dashboards
Make sure you have configured the configuration option jwt-url-parameter to the JWT integrator:
juju config jwt-integrator jwt-url-parameter="jwt"
After a few moments, you can access it by adding your JWT as a URL parameter in the Browser like this:
http://<ip-address>:5601?jwt=<your-jwt>
Help improve this document in the forum (guidelines). Last updated 2 months ago.
