| 2/stable | 168 | 24 Sep 2024 | |
| 2/candidate | 168 | 24 Sep 2024 | |
| 2/beta | 168 | 24 Sep 2024 | |
| 2/edge | 307 | Yesterday | |
| 2/edge | 306 | Yesterday |
22.04
All commands are written for juju v.3.1.7 +
How to configure Azure storage
This guide will teach you how to deploy and configure the Azure Integrator charm for Azure, send the configurations to the Charmed OpenSearch application, and update it.
Configure Azure integrator
First, deploy and run the azure-integrator charm:
juju deploy azure-storage-integrator --channel latest/edge
juju config azure-storage-integrator storage-account=<Azure_storage_account> container=<Azure_storage_container>
Then, add the the secret key to the charm:
juju add-secret mysecret secret-key=<Azure_storage_key>
juju grant-secret mysecret azure-storage-integrator
juju config azure-storage-integrator credentials=<secret-id>
See all other configuration parameters in the Configuration section of the azure-integrator documentation.
Integrate with Charmed OpenSearch
To pass these configurations to Charmed OpenSearch, integrate the two applications:
juju integrate azure-storage-integrator opensearch
