mongos-k8s
| 6/stable | 75 | 23 Jan 2026 | |
| 6/candidate | 75 | 23 Jan 2026 | |
| 6/beta | 75 | 23 Jan 2026 | |
| 6/edge | 158 | 16 Jul 2026 | |
| 8-transition/edge | 160 | 16 Jul 2026 | |
| 8-transition/edge | 159 | 16 Jul 2026 | |
| 8/stable | 74 | 23 Jan 2026 | |
| 8/candidate | 74 | 23 Jan 2026 | |
| 8/beta | 74 | 23 Jan 2026 | |
| 8/edge | 157 | 15 Jul 2026 | |
| 8/edge | 156 | 15 Jul 2026 |
juju deploy mongos-k8s --channel 6/edge
Major Version Upgrade
After having upgraded your sharded cluster using MongoDB documentation, you can proceed to deploy a new Mongos K8s application (see docs) and relate it with the config-server as you have done as part of the tutorial.
Please note that Mongos 6 and MongoDB 8 are not compatible so you have to update them separately.
