Kubeflow
- Kubeflow Charmers | bundle
- Cloud
1.10/stable | 436 | 07 Apr 2025 |
1.10/candidate | 434 | 02 Apr 2025 |
1.10/beta | 433 | 24 Mar 2025 |
1.9/stable | 432 | 03 Dec 2024 |
1.9/edge | 431 | 03 Dec 2024 |
This guide describes how to configure Charmed Kubeflow to perform inference on user owned KServe Inference Services (ISVCs) using programmatic access tokens, for example from a Jupyter Notebook.
To do so, follow these steps:
- Create a
ServiceAccount
token from inside a Notebook server with the following parameters:
TOKEN=$(kubectl create token \
default-editor \
--duration=<duration in s> \
--audience=istio-ingressgateway.kubeflow.svc.cluster.local)
The --audience
parameter has to be set to istio-ingressgateway.kubeflow.svc.cluster.local
for requests with this token to go through, otherwise they can be rejected.
- Pass the
TOKEN
to the request, for example:
curl $ISVC_URL/v1/models/model-endpoint \
-H "Authorization: Bearer $TOKEN" \
-H 'Content-Type: <content-type>' \
-d <data>
The ServiceAccount
token is bound to the default-editor ServiceAccount
that gets created for every Charmed Kubeflow user. That being said:
- The token will not be valid if the
is deleted. - The access cannot be revoked unless the
duration
set at creation time has expired.
