title: Charmhub | Deploy Apache Kafka Connect using Charmhub - The Open Operator Collection
description: Deploy the latest version of Apache Kafka Connect on any cloud.
url: https://charmhub.io/kafka-connect/docs/h-enable-monitoring
# Apache Kafka Connect
[Canonical](https://charmhub.io/publisher/data-platform "View all packages from Canonical")
* [Canonical](https://charmhub.io/publisher/data-platform "View all packages from Canonical")
22.04
4/stable 37
juju deploy kafka-connect --channel 4/stable
#### Relevant links
* [Homepage](https://github.com/canonical/kafka-connect-operator)
#### Contacts
##### Maintainers
+ [Canonical Data Platform](mailto:data-platform@lists.launchpad.net)
* [Submit a bug](https://github.com/canonical/kafka-connect-operator/issues)
# Enable monitoring
Both Charmed Apache Kafka and Charmed Apache ZooKeeper come with the [JMX exporter](https://github.com/prometheus/jmx_exporter/).
The metrics can be queried by accessing the `http://<kafka-unit-ip>:9101/metrics` and `http://<zookeeper-unit-ip>:9998/metrics` endpoints, respectively.
Additionally, the charm provides integration with the [Canonical Observability Stack](https://charmhub.io/topics/canonical-observability-stack).
Deploy the `cos-lite` bundle in a Kubernetes environment. This can be done by following the
[deployment tutorial](https://charmhub.io/topics/canonical-observability-stack/tutorials/install-microk8s).
Since the Charmed Apache Kafka is deployed directly on a cloud infrastructure environment, it is
needed to offer the endpoints of the COS relations. The [offers-overlay](https://github.com/canonical/cos-lite-bundle/blob/main/overlays/offers-overlay.yaml)
can be used, and this step is shown in the COS tutorial.
## [Offer interfaces via the COS controller](https://charmhub.io/kafka-connect/docs/h-enable-monitoring#p-25104-offer-interfaces-via-the-cos-controller)
Switch to COS K8s environment and offer COS interfaces to be cross-model related with Charmed Apache Kafka VM model:
# Switch to Kubernetes controller, for the cos model.
juju switch <k8s_controller>:<cos_model_name>
juju offer grafana:grafana-dashboard grafana-dashboards
juju offer loki:logging loki-logging
juju offer prometheus:receive-remote-write prometheus-receive-remote-write
## [Consume offers via the Apache Kafka model](https://charmhub.io/kafka-connect/docs/h-enable-monitoring#p-25104-consume-offers-via-the-apache-kafka-model)
Switch to Charmed Apache Kafka VM model, find offers and relate with them:
# We are on the Kubernetes controller, for the cos model. Switch to kafka model
juju switch <machine_controller_name>:<kafka_model_name>
juju find-offers <k8s_controller>:
A similar output should appear, if `k8s` is the K8s controller name and `cos` the model where `cos-lite` has been deployed:
Store      URL                                        Access  Interfaces
k8s        admin/cos.grafana-dashboards               admin   grafana_dashboard:grafana-dashboard
k8s        admin/cos.loki-logging                     admin   loki_push_api:logging
k8s        admin/cos.prometheus-receive-remote-write  admin   prometheus-receive-remote-write:receive-remote-write
Consume offers to be reachable in the current model:
juju consume <k8s_controller>:admin/<cos_model_name>.prometheus-receive-remote-write
juju consume <k8s_controller>:admin/<cos_model_name>.loki-logging
juju consume <k8s_controller>:admin/<cos_model_name>.grafana-dashboards
Now, deploy `grafana-agent` (subordinate charm) and relate it with Charmed Apache Kafka and Charmed Apache ZooKeeper:
juju deploy grafana-agent
juju relate kafka:cos-agent grafana-agent
juju relate zookeeper:cos-agent grafana-agent
Finally, relate `grafana-agent` with consumed COS offers:
juju relate grafana-agent grafana-dashboards
juju relate grafana-agent loki-logging
juju relate grafana-agent prometheus-receive-remote-write
Wait for all components to settle down on a `active/idle` state on both
models, e.g. `<kafka_model_name>` and `<cos_model_name>`.
After this is complete, the monitoring COS stack should be up and running and ready to be used.
## [Connect Grafana web interface](https://charmhub.io/kafka-connect/docs/h-enable-monitoring#p-25104-connect-grafana-web-interface)
To connect to the Grafana web interface, follow the [Browse dashboards](https://charmhub.io/topics/canonical-observability-stack/tutorials/install-microk8s?_ga=2.201254254.1948444620.1704703837-757109492.1701777558#heading--browse-dashboards) section of the MicroK8s “Getting started” guide.
juju run grafana/leader get-admin-password --model <k8s_cos_controller>:<cos_model_name>
## [Tune server logging level](https://charmhub.io/kafka-connect/docs/h-enable-monitoring#p-25104-tune-server-logging-level)
To tune the level of the server logs for Apache Kafka and Apache ZooKeeper, configure the `log-level` and `log_level` properties accordingly.
### [Apache Kafka](https://charmhub.io/kafka-connect/docs/h-enable-monitoring#p-25104-apache-kafka)
juju config kafka log_level=<LOG_LEVEL>
Possible values are `ERROR`, `WARNING`, `INFO`, `DEBUG`.
### [Apache ZooKeeper](https://charmhub.io/kafka-connect/docs/h-enable-monitoring#p-25104-apache-zookeeper)
juju config zookeeper log-level=<LOG_LEVEL>
