title: Charmhub | Deploy Hockeypuck K8S Charm using Charmhub - The Open Operator Collection
description: Deploy the latest version of Hockeypuck K8S Charm as a Kubernetes Operator
  on any cloud.
url: https://charmhub.io/hockeypuck-k8s/docs/reference-integrations
# Hockeypuck K8S Charm
[Canonical IS DevOps](https://charmhub.io/publisher/canonical-is-devops "View all packages from Canonical IS DevOps")
* [Canonical IS DevOps](https://charmhub.io/publisher/canonical-is-devops "View all packages from Canonical IS DevOps")
2.2/stable 20
juju deploy hockeypuck-k8s --channel 2.2/stable
#### Contacts
##### Maintainers
+ [Launchpad Team](https://launchpad.net/~canonical-is-devops)
* [Submit a bug](https://github.com/canonical/hockeypuck-k8s-operator/issues)
# Integrations
See [Integrations](https://charmhub.io/hockeypuck-k8s/integrations).
### [database](https://charmhub.io/hockeypuck-k8s/docs/reference-integrations#p-37636-database)
*Interface*: postgresql\_client
*Supported charms*: [Charmed PostgreSQL](https://charmhub.io/postgresql), [Charmed PostgreSQL-K8s](https://charmhub.io/postgresql-k8s)
The database endpoint can be integrated with PostgreSQL based charms, providing long term storage for Hockeypuck.
The database relation connects hockeypuck-k8s with charms that support the `postgresql_client` interface on port 5432
in the database side.
Example database integrate command:
juju integrate hockeypuck-k8s postgresql-k8s
### [grafana-dashboard](https://charmhub.io/hockeypuck-k8s/docs/reference-integrations#p-37636-grafana-dashboard)
*Interface*: grafana-dashboard
*Supported charms*: [grafana-k8s](https://charmhub.io/grafana-k8s)
Grafana-dashboard is a part of the COS relation to enhance observability.
The relation enables quick dashboard access already tailored to fit the needs of
operators to monitor the charm. The template for the Grafana dashboard for the
Hockeypuck charm can be found at `/src/cos/grafana_dashboards/hockeypuck.json`.
In the Grafana UI, it can be found as “Hockeypuck metrics” under the General section of the
dashboard browser (`/dashboards`). Modifications to the dashboard can be made but will not be
persisted upon restart or redeployment of the charm.
The Hockeypuck charm satisfies the `grafana_dashboard` interface by providing the
pre-made dashboard template to the Grafana relation data bag under the “dashboards” key.
Requires Prometheus datasource to be already integrated with Grafana.
Example Grafana-Prometheus integrate command:
juju integrate grafana-k8s:grafana-source prometheus-k8s:grafana-source
Example Grafana-dashboard integrate command:
juju integrate hockeypuck-k8s grafana-dashboard
### [ingress](https://charmhub.io/hockeypuck-k8s/docs/reference-integrations#p-37636-ingress)
*Interface*: ingress
*Supported charms*: [nginx-ingress-integrator](https://charmhub.io/nginx-ingress-integrator), [traefik-k8s](https://charmhub.io/traefik-k8s)
Ingress manages external HTTP/HTTPS access to services in a Kubernetes cluster.
Note that the Kubernetes cluster must already have an nginx ingress controller deployed.
Documentation to enable ingress in MicroK8s can be found
[here](https://microk8s.io/docs/addon-ingress).
Example ingress integrate command:
juju integrate hockeypuck-k8s nginx-ingress-integrator
### [logging](https://charmhub.io/hockeypuck-k8s/docs/reference-integrations#p-37636-logging)
*Interface*: loki\_push\_api
*Supported charms*: [loki-k8s](https://charmhub.io/loki-k8s)
The logging relation is a part of the COS relation to enhance logging observability.
Logging relation through the `loki_push_api` interface installs and runs promtail which ships the
contents of the Hockeypuck kubernetes pod logs to Loki.
This can then be queried through the Loki API or easily visualized through Grafana. Learn more about COS
[here](https://charmhub.io/topics/canonical-observability-stack).
Example logging-endpoint integrate command:
juju integrate hockeypuck-k8s loki-k8s
### [metrics-endpoint](https://charmhub.io/hockeypuck-k8s/docs/reference-integrations#p-37636-metrics-endpoint)
*Interface*: [prometheus\_scrape](https://charmhub.io/interfaces/prometheus_scrape-v0)
*Supported charms*: [prometheus-k8s](https://charmhub.io/prometheus-k8s)
The metrics-endpoint relation allows scraping the `/metrics` endpoint provided by Hockeypuck
on port 9626, which provides [Hockeypuck metrics](https://charmhub.io/hockeypuck-k8s/docs/reference-metrics).
Example metrics-endpoint integrate command:
juju integrate hockeypuck-k8s prometheus-k8s
### [traefik-route](https://charmhub.io/hockeypuck-k8s/docs/reference-integrations#p-37636-traefik-route)
*Interface*: [traefik\_route](https://charmhub.io/traefik-k8s/integrations#traefik-route)
*Supported charms*: [traefik-k8s](https://charmhub.io/traefik-k8s)
The traefik-route relation provides low-level access to Traefik configuration. Hockeypuck requires
this interface to expose the reconciliation port (11370) to [peer](https://hockeypuck.io/configuration.html#:~:text=1.4.-,Recon,-Hockeypuck%20supports%20the) with other keyservers.
Example traefik-route integrate command:
juju integrate hockeypuck-k8s traefik-k8s:traefik-route
