title: Charmhub | Deploy Hockeypuck K8S Charm using Charmhub - The Open Operator Collection
description: Deploy the latest version of Hockeypuck K8S Charm as a Kubernetes Operator
  on any cloud.
url: https://charmhub.io/hockeypuck-k8s/docs/how-to-reconcile-between-two-keyservers
# Hockeypuck K8S Charm
[Canonical IS DevOps](https://charmhub.io/publisher/canonical-is-devops "View all packages from Canonical IS DevOps")
* [Canonical IS DevOps](https://charmhub.io/publisher/canonical-is-devops "View all packages from Canonical IS DevOps")
2.2/stable 20
juju deploy hockeypuck-k8s --channel 2.2/stable
#### Contacts
##### Maintainers
+ [Launchpad Team](https://launchpad.net/~canonical-is-devops)
* [Submit a bug](https://github.com/canonical/hockeypuck-k8s-operator/issues)
# Reconcile between two key servers
Hockeypuck supports peering with other SKS-compatible key servers to synchronize public key data through **reconciliation**.
1. Create a file `peers.txt` and add the external peers you want to reconcile with. Each line must be in the following format:
<peer_address>,<http_port>,<reconciliation_port>
* `peer_address`: The IP or fully qualified domain name (FQDN) of the peer.
* `http_port`: The port where the peer exposes its SKS HTTP API (usually 11371).
* `reconciliation_port`: The port used for reconciliation (usually 11370).
Example `peers.txt`:
10.1.39.11,11371,11370
10.1.39.13,11371,11370
1. Configure the Hockeypuck charm to use the file through the `external-peers` config option:
juju config hockeypuck-k8s external-peers=@peers.txt
1. Check the Hockeypuck logs to confirm that reconciliation with external peers is taking place:
kubectl logs hockeypuck-k8s-0 -c app -n $JUJU_MODEL_NAME
You might find logs that look like the one below. The following logs are extracted from a Hockeypuck keyserver deployed in a secondary model and reconciled with a keyserver deployed in a primary model with a single key:
2025-04-17T05:26:59.063Z [go] time="2025-04-17T05:26:59Z" level=info msg="accepted recon from [recon=10.1.39.177:11370, http=10.1.39.177:11371, weight=0, addr=<nil>, ips=[10.1.39.177]]" label="serve :11370"
2025-04-17T05:26:59.066Z [go] time="2025-04-17T05:26:59Z" level=info msg="reconciliation done" label="serve :11370" remoteAddr="10.1.39.177:42586"
2025-04-17T05:26:59.066Z [go] time="2025-04-17T05:26:59Z" level=info msg="recovering 1 items" label="serve :11370" remoteAddr="10.1.39.177:42586"
2025-04-17T05:26:59.106Z [go] time="2025-04-17T05:26:59Z" level=info POST=/pks/hashquery duration=6.395046ms host="10.1.39.140:11371" status-code=200
2025-04-17T05:26:59.115Z [go] time="2025-04-17T05:26:59Z" level=info msg="Bulk insertion skipped (small number of keys). Reverting to normal insertion."
2025-04-17T05:26:59.159Z [go] time="2025-04-17T05:26:59Z" level=info msg=upsert inserted=1 label="recon :11370" remoteAddr="10.1.39.177:42586" unchanged=0 updated=0
2025-04-17T05:26:59.160Z [go] time="2025-04-17T05:26:59Z" level=info msg="recovery complete" label="serve :11370" remoteAddr="10.1.39.177:42586"
