title: Charmhub | Deploy Hardware Observer using Charmhub - The Open Operator Collection
description: Deploy the latest version of Hardware Observer on any cloud.
url: https://charmhub.io/hardware-observer/docs/metrics-and-alerts-hpe
# Hardware Observer
[Canonical BootStack Charmers](https://charmhub.io/publisher/bootstack-charmers "View all packages from Canonical BootStack Charmers")
* [Canonical BootStack Charmers](https://charmhub.io/publisher/bootstack-charmers "View all packages from Canonical BootStack Charmers")
24.04
22.04
20.04
18.04
stable 894
juju deploy hardware-observer
#### Relevant links
* [Homepage](https://github.com/canonical/hardware-observer-operator)
#### Contacts
* [Submit a bug](https://github.com/canonical/hardware-observer-operator/issues)
## [Metrics](https://charmhub.io/hardware-observer/docs/metrics-and-alerts-hpe#p-26508-metrics)
The details of the metrics exposed by Hardware Observer for HPE Smart Array Controllers are as follows:
| Metric Name | Description | Labels |
| ssacli\_command\_success | Indicates if the command is successful or not |  |
| ssacli\_controllers | Total number of controllers |  |
| ssacli\_controller\_info | Shows information about controller part | slot, part, status |
| ssacli\_logical\_drives | The number of logical drives in the slot | slot |
| ssacli\_logical\_drive\_info | Shows information about logical drive | slot, drive\_id, status |
| ssacli\_physical\_drives | The number of physical drives in the slot | slot |
| ssacli\_physical\_drive\_info | Shows information about physical drive | slot, drive\_id, status |
## [Alerts](https://charmhub.io/hardware-observer/docs/metrics-and-alerts-hpe#p-26508-alerts)
The details of the alerts that are provided by Hardware Observer for HPE Smart Array Controllers are as follows:
| Alert Rule Name | Description | Severity |
| SsaCLICommandFailed | Failed to run ssacli. | critical |
| SsaCLIControllerNotFound | ssacli controller not found. | warning |
| SsaCLIControllerNotOK | ssacli controller status not Ok. | critical |
| SsaCLILogicalDriveNotOK | ssacli logical drive status not Ok. | critical |
| SsaCLIPhysicalDriveNotOK | ssacli physical drive status not Ok. | critical |
