title: Charmhub | Deploy GitHub runner using Charmhub - The Open Operator Collection
description: Deploy the latest version of GitHub runner on any cloud.
url: https://charmhub.io/github-runner/docs/reference-token-scopes
# GitHub runner
[Canonical IS DevOps](https://charmhub.io/publisher/canonical-is-devops "View all packages from Canonical IS DevOps")
* [Canonical IS DevOps](https://charmhub.io/publisher/canonical-is-devops "View all packages from Canonical IS DevOps")
22.04
20.04
stable 24801f1f
juju deploy github-runner
#### Contacts
##### Maintainers
+ [Launchpad Team](https://launchpad.net/~canonical-is-devops)
* [Submit a bug](https://github.com/canonical/github-runner-operator/issues)
# Token scopes
In order to use the GitHub runner charm, a personal access token with the necessary permissions
is required.
## [Fine grained access token scopes](https://charmhub.io/github-runner/docs/reference-token-scopes#p-31897-fine-grained-access-token-scopes)
**Note**: In addition to having a token with the necessary permissions, the user who owns the
token also must have admin access to the organisation or repository.
### [Organizational runners](https://charmhub.io/github-runner/docs/reference-token-scopes#p-31897-organizational-runners)
The following are the permissions scopes required for the GitHub runners when registering as an
organisational runner.
Organisation:
* Self-hosted runners: read & write
Repository:
* Actions: read (required if COS integration is enabled and private repositories exist)
* Administration: read
### [Repository runners](https://charmhub.io/github-runner/docs/reference-token-scopes#p-31897-repository-runners)
repository runner.
* Actions: read (required if COS integration is enabled and the repository is private)
* Administration: read & write
* Metadata: read
## [Personal access token scopes](https://charmhub.io/github-runner/docs/reference-token-scopes#p-31897-personal-access-token-scopes)
Depending on whether the charm is used for GitHub organisations or repositories, the following scopes
should be selected when creating a personal access token.
To use this charm for GitHub organisations, the following scopes should be selected:
* `repo`
* `admin:org`
To use this charm for GitHub repositories, the following scopes should be selected:
* `repo`
