title: Charmhub | Deploy Canonical Observability Stack Proxy using Charmhub - The
  Open Operator Collection
description: Deploy the latest version of Canonical Observability Stack Proxy on any
  cloud.
url: https://charmhub.io/cos-proxy/docs/solution-matrix
# Canonical Observability Stack Proxy
[Canonical Observability](https://charmhub.io/publisher/observability "View all packages from Canonical Observability")
* [Canonical Observability](https://charmhub.io/publisher/observability "View all packages from Canonical Observability")
24.04
22.04
20.04
3.0/stable e6f880c
juju deploy cos-proxy --channel 3.0/stable
# Solution matrix
|  | K8s charm | Machine charm | Legacy charms - LMA deps | Non-juju workload |
| [Logs](https://discourse.charmhub.io/t/cos-lite-docs-logging-architecture/13926) | [LokiPushApiConsumer](https://charmhub.io/loki-k8s/libraries/loki_push_api) (for workloads that can communicate directly with Loki, [LogProxyConsumer](https://charmhub.io/loki-k8s/libraries/loki_push_api) (installs promtail in the workload; not suitable for air-gapped), LogForwarder (pebble-native, Juju>=3.4.1) | [cos\_agent](https://charmhub.io/grafana-agent/libraries/cos_agent) (subordinate, pulls logs from `/var/log` or from other snaps with a matching slot) | [cos-proxy](https://charmhub.io/cos-proxy) | [grafana-agent snap](https://snapcraft.io/grafana-agent) (manually configured) |
| Metrics | [prometheus\_scrape](https://charmhub.io/prometheus-k8s/libraries/prometheus_scrape) (in-model), [prometheus\_remote\_write](https://charmhub.io/prometheus-k8s/libraries/prometheus_remote_write) (CMR) - with grafana-agent | [cos\_agent](https://charmhub.io/grafana-agent/libraries/cos_agent) | [cos-proxy](https://charmhub.io/cos-proxy) | [scrape-target](https://charmhub.io/prometheus-scrape-target-k8s), [grafana-agent snap](https://snapcraft.io/grafana-agent) |
| Traces | [tracing](https://charmhub.io/tempo-k8s/libraries/tracing) (instrumented workloads), [charm\_tracing](https://charmhub.io/tempo-k8s/libraries/charm_tracing) (for the charm itself) | [tracing](https://charmhub.io/tempo-k8s/libraries/tracing) (CMR), [cos\_agent](https://charmhub.io/grafana-agent/libraries/cos_agent) | N/A | [grafana-agent charm](https://charmhub.io/grafana-agent-k8s) |
| Dashboards | [grafana\_dashboard](https://charmhub.io/grafana-k8s/libraries/grafana_dashboard), [cos-configuration](https://charmhub.io/cos-configuration-k8s) | [cos\_agent](https://charmhub.io/grafana-agent/libraries/cos_agent), [cos-configuration](https://charmhub.io/cos-configuration-k8s) | [cos-proxy](https://charmhub.io/cos-proxy), [cos-configuration](https://charmhub.io/cos-configuration-k8s) | [cos-configuration](https://charmhub.io/cos-configuration-k8s) |
| Alert rules | via metrics and logs relations, [cos-configuration](https://charmhub.io/cos-configuration-k8s) | [cos\_agent](https://charmhub.io/grafana-agent/libraries/cos_agent), [cos-configuration](https://charmhub.io/cos-configuration-k8s) | [cos-proxy](https://charmhub.io/cos-proxy), [cos-configuration](https://charmhub.io/cos-configuration-k8s) | [cos-configuration](https://charmhub.io/cos-configuration-k8s) |
* The [COS Lite bundle](https://charmhub.io/cos-lite) does not include tracing by default; however, there’s a bundle overlay for that.
## [External links](https://charmhub.io/cos-proxy/docs/solution-matrix#p-28473-external-links)
* [Monitoring Agents Comparative Study](https://wiki.anuket.io/display/HOME/Monitoring+Agents+Comparative+Study)
* [How to integrate COS-Lite with non-juju workloads](https://discourse.charmhub.io/t/12005)
